Read more
Problem with Morph intersection
With objects created using tools beside the morph tool, the way they intersect corresponds to their building material's intersection priority, but somehow I'm experiencing a problem with a chimney I created using the morph tool.
The building material for the morph is Stainless Steel, which has an intersection priority higher than that of the roof's materiel ( 900 to 300 )... but when I hide the layer the chimney is on or filter elements in 3D, there's no hole in the roof. Do I have to manually perform Solid Element Operations? I can't seem to find out what's wrong.
4 REPLIES 4
See Attachment.
James B
With morph it does not automatically intersect with elements. You need to use the Connect > Merge Elements from the context menu for the intersection priority to take affect with Morph.
Basic Intersection Principles
James Badcock
Graphisoft Senior Product Manager
wow, this is embarrassing, I thought I learned all the basics by now... thanks a lot!
Good to know as well.
Thanks a lot
