‎2008-02-13
06:04 PM
‎2023-05-23
03:13 PM
Rubia Torres
‎2008-02-13 07:22 PM
‎2008-02-14 01:26 PM
Dom wrote:
I'd use the roof intersection command (selecting the first roof - ctrl*click the second roof) This method will deterime where on the plan the roofs will intersect as well as adjust the angle of intersection between the two roofs to compensate for the difference in roof slope.
‎2008-02-14 04:07 PM
sinatropus wrote:I've had a similar problem.
Already did that. In 3D the intersections are absolutely correct, that's why this situation in floor plan is peculiar. Is this common?
‎2008-02-14 04:52 PM
Thomas wrote:sinatropus wrote:I've had a similar problem.
If your model is correct and the issue pertains only to the floor plan, the easiest way around this is to use a 2D patch (marquee the area, Document Extras > Create Patch)
