Problem with wall complex profile,please help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2012-12-20
04:23 PM
2023-05-24
12:51 PM
Rubia Torres
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-20 06:29 PM
Tough to tell what is happening with just a plan view however,
Check to make sure View>On Screen View Options> Clean Wall Beam
Intersections is toggled on.
It appears that you have a footing with a stem wall, make sure your
wall reference lines touch. Where is the reference line for the comp. wall
(outside edge of footing?), Try moving the reference line to the stem wall.
Lastly, the priority for the footing should be lower then the stem wall.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-23 11:37 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-23 11:43 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-23 11:45 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-23 05:04 PM
The only way to get the plan view to show correctly is to split your wall
in to 2 pieces and model them separately ie model the footing and then
model the wall on top of it, if you use the same fill for both, they will
appears as one in section
Hope that helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-23 07:02 PM
you have to set "Cut Plane height to Current Story" for the complex profile foundation Walls under the menu Document / Floor Plan Cut Plane Settings.
From the dimensions of the profile I guess your height is set to 110cm. Set it to 100cm!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-23 07:03 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-23 09:47 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-25 10:31 AM
Walls with footings are usually drawn (and built) as separate elements with the stem and the footing shown as separate fill elements (see below) even if you're using the same fill type for both. Sort of like what Dave Seabury was suggesting but rather than actually modelling it as 2 separate construction elements, you only draw it as 2 separate fill elements (in the Complex profile manger) even though they work as one element on plan and are built as one wall with footing in 3D and section.
This way you would be able to set the priorities for the stem and the footing separately in the Complex profile manager and have it clean up correctly in your plan along with section and detail drawings.
It would also allow you to set separate properties for the footing in plan (like controlling dash-line segments to show footing as hidden line contours in plan for only just footing - although ArchiCAD allows you to do this automatically but with less control on the wall view properties).
I realize that this is probably not at the level of your architectural education at this point yet, but if you stick with Architecture, eventually you're going to have to learn how it's done.
See the images below for how a wall with footing is drawn or represented (and constructed) complete with keyway.
