License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
2012-12-2004:23 PM - last edited on 2023-05-2412:51 PM by Rubia Torres
2012-12-2004:23 PM
My problem is with the ensembles of the walls in the floor plan of the complex profiles, there is a solution to the Wall Priority Structure and Composite but I've tried, but no go. I drawing the concrete foundation, and I really would ask you to explain to me, or if there is some tutorial because this problem can not seem to solve. Please help me!
I routinely model complex profile walls with the footing and foundation wall in the same complex profile. It works great. Heck, I even add the 2x plate at the top of the foundation. The footing comes out as a dashed line because it is below the cut plane.
I set the vertical stretch lines above the footing and below the plate, so when I stretch the wall, it does not affect the footing or plate.
How did you get the footing section to display as dashed lines in plan view?
I have done it by making two elements and setting the footing to overhead projection but if it can be accomplished in one profile, one step, that would be much better.
