Problems with delay w/ copy command (cmd-C)
Currently running AC10 on Mac Dual 1.8 GHz G5 w/ 1.5 GB DDR RAM on OSX 10.3.9.
Having problems with copy command (cmd C). When copying elements from story to story there is a 10 second delay or 'freeze-up' after I hit 'cmd C' to execute the copy command. It happens even if I am only copying a single line segment.
I am also experiencing odd program behavior when i 'option-click' objects (inject parameters). It will often ignore the fact that i 'option-click' and just select the object or start the 'line' command instead. It usually takes several attempts before if finally works.
Any suggestions would be helpful as it slowing down our production.
0 REPLIES 0
