Question: how to write on a wall?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2009-03-26 04:14 PM
is it possible to create a writing on the wall?
I would like to have a writing, like a neon sign, on a wall for viewing in 3D and render. Nothing "special" just a plain simple letters attached to a wall (in metal) with an illumination behind them.
I hope you understood what I am talking about, since my architectural english isn't quite good (yet, but hopefully this will change).
Thank you in advance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-03-26 05:57 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-03-26 05:59 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-03-26 06:07 PM
It seems in Artlantis that as soon as the heliodon is activated, the power of other lights diminishes.
Here is a similar light that is also suppressed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-03-26 06:08 PM
Matteo wrote:I made the letters 2" (5 cm) thick and offset them by the same amount (5 cm).
Karl, thank you very much (and all others as well). May I ask you how much distance did you put between the text and the wall?
With ArchiCAD alone, you cannot directly fake the illumination in one step. But, if you are generating still images (not animation), you might be able to fake it with one of these ideas:
You could turn off the letters and render the scene with one or more light sources creating the desired glow on the wall. Then render just the constant glowing letters against a constant color background to use for masking. Overlay the letters on top of the main render in Photoshop (gimp, etc). If you need shadows too (not fully dark), fake them in Photoshop in the classic Photoshop way.
Or, you could create a special material for the wall in Photoshop which maps to the entire wall and onto which you have painted, in Photoshop, the necessary glowing area. Assign that image to a new material, sized to the wall, and align it to the wall with the Align in 3D command. Illuminate the scene with only ambient lighting. You could even do an animation with this approach.
Either is a bit of work though, and not sure how good the results would be?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-03-26 06:11 PM
Dwight wrote:Beautiful, Dwight! Settings tips for that one in your forthcoming book?
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-03-26 06:33 PM
Very slow going.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-03-27 11:39 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-03-27 02:07 PM
ofc, this is not artlanits
no faking !
i have problem with my moitor its not calibrated so image can be display wrong at your monitors !
low quality image !
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-03-27 02:42 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-03-27 06:09 PM
The usual problem with this effect is that the light is too strong.
How do you contain the light?
Here is a neon solution in LightWorks that could be a backlite, too.
