Matteo wrote:
Karl, thank you very much (and all others as well). May I ask you how much distance did you put between the text and the wall?
I made the letters 2" (5 cm) thick and offset them by the same amount (5 cm).
With ArchiCAD alone, you cannot directly fake the illumination in one step. But, if you are generating still images (not animation), you might be able to fake it with one of these ideas:
You could turn off the letters and render the scene with one or more light sources creating the desired glow on the wall. Then render just the constant glowing letters against a constant color background to use for masking. Overlay the letters on top of the main render in Photoshop (gimp, etc). If you need shadows too (not fully dark), fake them in Photoshop in the classic Photoshop way.
Or, you could create a special material for the wall in Photoshop which maps to the entire wall and onto which you have painted, in Photoshop, the necessary glowing area. Assign that image to a new material, sized to the wall, and align it to the wall with the Align in 3D command. Illuminate the scene with only ambient lighting. You could even do an animation with this approach.
Either is a bit of work though, and not sure how good the results would be?
š
