You are limited concerning illumination within ArchiCAD.
As Dwight has pointed out, you can use a 'constant' LightWorks shader (visible only when rendered with LW, not in OpenGL or internal engine) to make the neon letters appear to be emissive - but they will not actually cast light on the wall.
3D text settings attached first...
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
