Question related to complex truss
i want to do this comlex shape truss can anyone guide me method of how i can do it i will be glad if there is snapshots explaining it
Thanks for you all
Can you show some Top and Side Views of the Trusses?
Specifically, do the trusses get less wide horizontally toward the middle part?
NCornia
Graphisoft Alumni
Graphisoft Alumni
Well this is a quick and dirty way. Draw the side view of the truss as a complex profile and apply it to a beam. Then make a complex profile of multiple triangular shapes and apply to a column of similar dimensions as original profiles beam.
Then intersect the two objects. Perform a subtraction seo with column as operator and voila.
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
@laszlonagy
i do not have the file it is image that i want to imitate it in archicad design
@NCornia
Thanks, I am hardly able to apply the explanation i will be grateful if you was able to provide a video by steps done thanks again
