4 hours ago
i HAVE A GREAT EXAMPLE OF WHERE RAILINGS GO - HOWEVER
The panel setting on one area of htre railing is not the same as the panel setting on the other.
I need something line a panels all 4' wide and a column at every 4'.
4 hours ago
Make sure your segment pattern settings length is set to a fixed length of 4' or probably better equally distributed with a max length of 4'
Then make sure you have an inner post placed with the settings you require.
If that is all one railing in your image and you see a little yellow warning triangle in the settings next to segments, that means you have different settings for each segment.
You will then have to 'Edit' each segment separately, or at the very bottom left when you select the segments in the railing settings, you can 'Reset Custom Segments' and they will all revert to the same settings.
