Railing Tool and Inner Posts -- what am I missing?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2017-07-06
05:46 PM
2023-05-23
06:05 PM
Rubia Torres
What am I missing?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-07-06 09:57 PM
In the Segment Pattern Settings panel of the Segment page of the Dialog, there are additional settings about Pattern distribution which can override this. Maybe the Segment is set to have 2 Divisions which can cause the Railing Pattern to be generated this way.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-07-06 10:11 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-07-06 11:00 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-07-13 08:18 PM
In the attached screenshot, Posts are indicated by green lines and the Inner Post by the red. Both Inner Posts and Balustrades are set to "Equally Distribute Pattern" -- neither are distributed equally. I've tried adjusting the "Pattern Continuity" parameter and there's no change.
(I question the screwy landing in another post):
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-07-13 08:24 PM
I don't need a handrail at the landing, only at the stair, so I've deleted the handrail from the landing segments. It looks like End Settings are exclusively for the end of Railing NOT end of Rail/Handrail.
Of course, if I end up modeling the landing separately (and thus end up with 2 separate Railings) this issue may be solved.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-07-14 06:42 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-07-15 08:27 PM
If you can save the Stair and Railing in a stripped down ARCHICAD file, save it as PLA and put it up on Dropbox or similar, I could take a look at it, but from these screenshots I cannot pinpoint what could be causing this behaviour.
By the way, the Railing context menu contains the Convert Pattern to Segment Length command. If you use it, each Pattern repetition will be considered a separate segment and you can move each Inner Post to the desired position.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-07-15 08:32 PM
Laura wrote:This is again handled by the "Convert Pattern to Segment Length" context menu command. Using the command will make Handrail segments of Flights and Landing independent of each other so they can be modified individually.
On another note, looks like I may have to model handrails separately, too.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-07-17 07:18 PM
laszlonagy wrote:This is more information than is provided in the Help (see attached).
