Railing-independent segment
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-07-15
05:26 PM
‎2023-05-23
05:58 PM
Rubia Torres
‎2021-07-15
05:26 PM
TK.
14 REPLIES 14
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-26 04:49 PM
‎2021-07-26
04:49 PM
To answer both recent questions...am not making independent segments but trying to make segments have different railing patterns.
Have placed associative railing via gravity to mesh. In between the points where railing has automatically associated to the mesh, I've placed several points by clicking without the gravity connection. When I select the entire railing, no right click "create independent segment" command shows up. So then I go to edit. I can select individual segments and change the railing pattern. However it is not only the selected segment that changes the pattern, but others as well for no apparent reason that I can discern. Sometimes it will only change the selected segment, sometimes one or two others. It seems some of the segments are still linked in some manner.
I'm sure it must be some simple thing I've overlooked. Maybe part of the railing is static, part is associative?
TK.
TK.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-27 03:10 AM
‎2021-07-27
03:10 AM
Can you show a 3D image of the railing with it selected so we can see where the nodes are?
Also indicate what segments you want to change.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-27 03:31 AM
‎2021-07-27
03:31 AM
Tom wrote:Possibly the same, have not found a solution other than how it is initially drawn;
However it is not only the selected segment that changes the pattern, but others as well for no apparent reason that I can discern.The connected segments should still highlight together when you use the
Ling.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-27 06:12 PM
‎2021-07-27
06:12 PM
Ling: In reference to your autopath comment.....am assuming it is not the "autogroup" command. If not, than I am not familiar how one invokes "autopath". Is it segment associativity in the railing dialogue box?
Thanks TK.
Thanks TK.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-28 03:43 AM
‎2021-07-28
03:43 AM
Tom wrote:When you associate a railing to some entity, you can select two nodes that are not adjacent and the
Ling.
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
