2021-06-30
11:25 AM
2025-02-05
12:12 PM
Aruzhan Ilaikova
2023-03-07 07:49 AM
I just gave it a quick try and it doesn't seem to work.
Even forgetting the macro call and just changing the post script to PROJECT2 doesn't work.
But oddly if I script a CIRCLE2 it does show a circle.
So it will draw what you want it to draw.
It is just finding out how to get the custom profile shape.
Maybe there is no PROJECT2 view of a custom profile?
Maybe it will be a case of REQUESTing the profile geometry and then reconstructing it with a polygon?
I don't have time to explore this at the moment though.
2023-03-07 07:52 AM
Thanks for looking into it @Barry Kelly
Definitely something to explore further because I doubt I'm the only one that would love to see this as a possibility. Perhaps they need to be done as morph's as per your original test rather than complex profiles? I do wonder if this would limit the vertical flexibility however.
The application to show profiled steel members would also be really helpful.
TBC
2023-05-09 11:09 AM
I'll jump on this thread with a related issue. I'm trying to create a solution for hedging using the railing tool - i.e. using Inner Posts as plants of different sizes and spcifying planting distance. This should then be able to be quantified simply by counting inner and outer posts.
The problem:
The 2D symbol always defaults to a size that fits into a 1000mmx1000mm bounding box - no matter which size the symbol is drawn.
I have "plants" that are 800mm diameter and 2000mm dia - all show up as 1000 "symbol"
Screenshot attached with all different options. To the left is the original symbol - to the right is the railing.
2023-05-10 04:17 AM
Is there a MUL2 at the start of your plant scripts? My guess is that it is scaling it to a unit size so that it can be correlated to A and B. That is what occurs when you save something out of the floorplan.
Ling.
2023-05-12 01:09 PM
Thanks Ling,
I will have a look.
I have gone the easy route and just saved 3D and 2D from work space - so have not double checked the script.
