Piotr
Railing tool - profiled post on plan
Hi all
Is there any way to display profiled post properly on plan? Don't see any option for this in railing or in MVO settings.
AC23
Regards
Piotr
14 Replies 14
I just gave it a quick try and it doesn't seem to work.
Even forgetting the macro call and just changing the post script to PROJECT2 doesn't work.
But oddly if I script a CIRCLE2 it does show a circle.
So it will draw what you want it to draw.
It is just finding out how to get the custom profile shape.
Maybe there is no PROJECT2 view of a custom profile?
Maybe it will be a case of REQUESTing the profile geometry and then reconstructing it with a polygon?
I don't have time to explore this at the moment though.
PLVT
Thanks for looking into it @Barry Kelly
Definitely something to explore further because I doubt I'm the only one that would love to see this as a possibility. Perhaps they need to be done as morph's as per your original test rather than complex profiles? I do wonder if this would limit the vertical flexibility however.
The application to show profiled steel members would also be really helpful.
TBC
Erik Bjornhage
I'll jump on this thread with a related issue. I'm trying to create a solution for hedging using the railing tool - i.e. using Inner Posts as plants of different sizes and spcifying planting distance. This should then be able to be quantified simply by counting inner and outer posts.
The problem:
The 2D symbol always defaults to a size that fits into a 1000mmx1000mm bounding box - no matter which size the symbol is drawn.
I have "plants" that are 800mm diameter and 2000mm dia - all show up as 1000 "symbol"
Screenshot attached with all different options. To the left is the original symbol - to the right is the railing.
Erik Bjornhage : SwedishChef, INSIKT Digital Sapiens, Gothenburg, Sweden - Architect : Digital Development : Graphisoft Cert. BIM-Manager - Eriks LinkedIn : INSIKT
ThinkPad P1 G7; Ultra9 185H; 64 GB; RTX 4070 [8GB] : AC12 - future
Lingwisyer
Guru
Is there a MUL2 at the start of your plant scripts? My guess is that it is scaling it to a unit size so that it can be correlated to A and B. That is what occurs when you save something out of the floorplan.
Ling.
Erik Bjornhage
Thanks Ling,
I will have a look.
I have gone the easy route and just saved 3D and 2D from work space - so have not double checked the script.
