Reflected Ceiling Plans - best technique
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2010-02-02
05:22 PM
2023-05-23
04:51 PM
Rubia Torres
I have an RCP I need to do.
I have a 'slab object' that is the ceiling.
it's 8'-0" off the story floor height.
it's 2" thick slab object, has the grid attached to it as vectoral hatch pattern.
I need to be able to put RCP objects, such as supply grilles, return grilles, lights...whatever, to a specific grid intersection, yet I cannot do that because the lines being used by the vectoral hatch don't have intersections as points I can select.
What is the best way to 'make/force' the vectoral hatch lines in the 2x2 grid pattern to be "clickable" so I can select intersections?
I've tried the "move the grid" origin to a location where there is an intersection on the celing but that gets cumbersome when each ceiling in each space has a different orgin point.
Another work around I've done is draw 2d plines 2 feet on center both horizontally and vertically. that's ok I suppose but I want the 2" thick slab object to show the grid pattern in 3d as well as it be intersectable in 2d????
Help and thanks in advance.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-02-02 10:16 PM
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-02-02 11:00 PM
Dennis wrote:good observation.
BTW, off topic, if those partitions continue past the ceiling in section (as shown in the 3d view), shouldn't you have your grid separate for each room? Or are your partitions anchored to the bottom of the ceiling grid only?
partitions should only go to underside of ceiling. they should not go thru in this particular case. the ceiling grid is not "cut" in the field rather the offices only have partition to underside of ceiling.
i>u
Edgewater, FL!
SOFTWARE VERSION:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-02-02 11:09 PM
I'm sorry if you misunderstood my question. it appears it is not as easy as it seems to express a point in a text comment vs. in real life. i'm sure in 100 years will get there though. So just to be clear.....there's no "heated reaction" here.
it simply seems to me that a simple "intersection snap toggle" may go along way in future versions. Typical ceiling intersections are most common throughout the architectural practice.
I've been using Archicad now since release 9. Did a 52,000 s.f. cruise ship terminal facility with it out of San Diego.....you can see it here.
http://www.youtube.com/watch?v=yOAsN54kCp0
I designed the terminal, created the DWG's in archicad and well, the rest is history so I am familiar with the software.
i'm simply suggesting a simply approach to snapping to grid lines for ceiling construction documentation functionality.
Matthew wrote:rob2218 wrote:From the programmer's point of view this ia not a simple matter. Programming for special case conditions leads to cumbersome, complicated and difficult to maintain software. Many of the complaints we have here in the forums are due to just such decisions made in long ago to accommodate the hardware limitations of the day.
"NOT" being able to snap to two basic intersecting lines is ridiculous.
I'm not asking and no where did I ask for ALL the hatch patterns to be "snappable" to.........i'm merely asking for the a typical (which there are millions of commercial and residential work here in the U.S. and Internationally) samples where the intersecting lines of a 2x2 or a 2x4 ceiling grid would be of most benifit and time savings............NOT ALL THE HATCH PATTERNS need snaps to them.
I mean seriously folks...a 2x2 ceiling grid is typical very typical in construction.....
Realistically if GS were to implement this it seems they would have to enable the snaps for all vector fills or they will be buried with complaints from all the folks who want it for some purpose other than ceiling tiles. Practically speaking this means there needs to be a function to turn this feature on and off in a way that is convenient to its use.
This could be the keyboard toggle as I described before, or perhaps a new setting in the fill attributes to enable snaps for specific fills.
I am just suggesting a way that this could be done. I really don't understand your heated reaction.
You are also ignoring the more obvious solution of simply having a properceilingtool instead of cobbling them together from slabs and roofs and other bits.
i>u
Edgewater, FL!
SOFTWARE VERSION:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-02-02 11:15 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-02-03 12:31 AM
Laura wrote:
Perhaps it would be best to wish for [have you placed your Wish?] a Ceiling Tool as opposed to snappable Fills. This would also help with IFC translation, I believe, but Matthew knows better.
i>u
Edgewater, FL!
SOFTWARE VERSION:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-02-03 09:45 AM
There's also an addon produced by CIGRAPH called archipanel and it's been created just for raised floors and false ceilings.
Have a look at it.
www.cigraph.it
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-02-03 03:31 PM
Laura wrote:Of course a ceiling tool is the proper solution. Having modeled over a million sf of ceilings this has been a priority wish of mine for years. The IFC problem is significant. By default they are exported as floors (or roofs, depending on the tool used).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-02-04 01:06 AM
I have been using and teaching versions of the following technique since AC6.5...
This is a link to one of my archived newsletters, the technique is described in the "ArchiTIP" section.
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-02-04 01:33 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-02-04 01:43 AM
AC 5.1-25 USA
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
