‎2010-02-02
05:22 PM
‎2023-05-23
04:51 PM
Rubia Torres
‎2010-02-02 10:16 PM
another Moderator
‎2010-02-02 11:00 PM
Dennis wrote:good observation.
BTW, off topic, if those partitions continue past the ceiling in section (as shown in the 3d view), shouldn't you have your grid separate for each room? Or are your partitions anchored to the bottom of the ceiling grid only?
‎2010-02-02 11:09 PM
Matthew wrote:rob2218 wrote:From the programmer's point of view this ia not a simple matter. Programming for special case conditions leads to cumbersome, complicated and difficult to maintain software. Many of the complaints we have here in the forums are due to just such decisions made in long ago to accommodate the hardware limitations of the day.
"NOT" being able to snap to two basic intersecting lines is ridiculous.
I'm not asking and no where did I ask for ALL the hatch patterns to be "snappable" to.........i'm merely asking for the a typical (which there are millions of commercial and residential work here in the U.S. and Internationally) samples where the intersecting lines of a 2x2 or a 2x4 ceiling grid would be of most benifit and time savings............NOT ALL THE HATCH PATTERNS need snaps to them.
I mean seriously folks...a 2x2 ceiling grid is typical very typical in construction.....
Realistically if GS were to implement this it seems they would have to enable the snaps for all vector fills or they will be buried with complaints from all the folks who want it for some purpose other than ceiling tiles. Practically speaking this means there needs to be a function to turn this feature on and off in a way that is convenient to its use.
This could be the keyboard toggle as I described before, or perhaps a new setting in the fill attributes to enable snaps for specific fills.
I am just suggesting a way that this could be done. I really don't understand your heated reaction.
You are also ignoring the more obvious solution of simply having a properceilingtool instead of cobbling them together from slabs and roofs and other bits.
‎2010-02-02 11:15 PM
‎2010-02-03 12:31 AM
Laura wrote:
Perhaps it would be best to wish for [have you placed your Wish?] a Ceiling Tool as opposed to snappable Fills. This would also help with IFC translation, I believe, but Matthew knows better.
‎2010-02-03 09:45 AM
‎2010-02-03 03:31 PM
Laura wrote:Of course a ceiling tool is the proper solution. Having modeled over a million sf of ceilings this has been a priority wish of mine for years. The IFC problem is significant. By default they are exported as floors (or roofs, depending on the tool used).
‎2010-02-04 01:06 AM
‎2010-02-04 01:33 AM
‎2010-02-04 01:43 AM
