2023-10-16 03:38 PM
Hey,
How do I remove a hole from a wall that was created by a window that I converted to morph and later deleted?
Only option to draw a new wall? There should not be a hidden object in there because I deleted the entire morph as it was grouped.
2023-10-16 03:48 PM
I think you can right click the wall > connect > delete all conections
2023-10-17 03:45 AM
Just select the opening by a corner node and delete it.
2023-10-17 08:12 AM
I tried that. It is not selectable. If I make an actual opening in a wall then I can select it and delete it. Even tho I have all the layers on, this opening cannot be selected. I have tried it with different tools active and from different angles and it just does not select. I guess I have to make a new wall in this case.
Clearing connections does not work either. The hole is still present.
2023-10-17 09:08 AM
I just converted a window into a morph.
Deleted all of the morph and I was left with a simple window opening.
I could select that by any corner node and delete it.
I am not sure why you are unable to select your opening.
2023-10-19 10:43 AM
Thank you, Barry and Ricardo.
I ended up drawing a new wall. For some reason, I just could not select an opening in any way I tried. It just selected the wall.
Even if I marquee selected the wall with an opening it showed me that I had only 1 object selected.
