AndorSzoke
!Restored: ArchiCAD 11 Hotfix (build 1112)
Dear ArchiCAD-Talkers,
We have released Hotfix 1112 for ArchiCAD 11 INT version. It applies to Commercial, Trial and Educational licenses. Before installing the Hotfix, please take a moment to read the Release Notes!
To download the Hotfix, please use "Check for updates..." command in Help menu.
Important note for MAC users: We don't recommend upgrading your system to MAC OS 10.5 due to a problem of the WIBU Server Software version 5.20 on MAC OS 10.5. We will make the new WIBU Server Software available as soon as it passes the QC test.
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
58 Replies 58
I Say Thanks to Graphisoft R&D Team
My AC11 Build 1086 and My Library is up to date..
Regards
Eddy Rachmat
How about US?
nothing showing up here either
is this available yet?
thanks
yukioMishima
Joseph wrote:
How about US?
The localized versions (US, GER, etc) have historically been released within days of the INT release, often the next day.
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Rakela Raul
often the next day.
right on
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
It may be worth mentioning that the US update is currently there.
Richard
AC26 (since AC6.0), Win10
hypothetically, let's say one did not read the release notes 'carefully' as recommended and experienced some hypothetical adverse display behaviors.
How would one go about stepping back to the previous hotfix, hypothetically, of course...
You would have to uninstall / reinstall AC, then install the prior hotfix. If you don't still have the older hotfix file, it can be downloaded again from the links on the update page.
Erika Epstein
I installed this latest hotfix and now have several problems:
it takes 20-30 seconds to autosave and one can't do anything while this is going on.
2. Very slow placing a new library part from AC11 lib
3. It consistantly crashes when going to the 3D window, OpenGL, even if only 1 object which has been in the model for months is selected.
Did a clean install of AC11 and then reinstalled patch, still crashes.
What a piece of @(#*&@)@#
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
