!Restored: Drawing titles
Please see the following link:
http://screencast.com/t/hrCiQdlH
I'm just trying to swap out the plain circle on my drawings title with a circle with a line through it.
Thanks for the help.
chris
7 REPLIES 7
Eduardo Rolon
In your drawing settings choose title and choose "title with layout…".
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Stress Co_
Off topic.....
Chris:
An easier way to post a screen shot:
Use the Mac OS shortcut: command-shift-4
It will turn your cursor to a cross-hair. Click, hold, Drag, unclick.
This will create a PNG on your desktop.
In "Post a reply" under filename click "choose File" and select the PNG
Marc Corney, Architect
Red Canoe Architecture, P. A.
Chris
Little B____lives here.
Bier
update:
Ops, think 11 is different.
In my 11, "it" lives here.
Bier
HAZAA, trĆØs bon, muy bueno, sehr gut and yippee.
But one question.
Under the title types I have titles numbered 11. Are there titles 1-10 and 12-XX lurking somewhere?
Thanks, and I'll try to remember the pic posting thingy. Thanks for that too.
Chris
Well your not going to have 12xx as you listed because I now see you are on 11.
"Title with Layout 11" should be there and work for you.
I tested that one and it has line dividing top and bottom.
I'm assuming I have 10 stuff because I migrated this project from 10 and loaded (object library 10.lcf) along with AC 11 library because of the migration to 11, or at least that's why I think I have it. For me it causes some duplications, but I just ignore that,
Others may be AGAST at that!
I'm assuming you have tried what eduardo suggested.
He knows this program a lot better than I.
And... after all I'm PC, just NOT "Politically Correct", (don't want to be a drone).
Bier
and just what the heck does:"HAZAA, trĆØs bon, muy bueno, sehr gut and yippee". mean?
Very good hippy?
Erika Epstein
Watch your language.
That was inappropriate.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
