!Restored: No solid fills in section/elevation
Dave Jochum
I feel like I'm in the Twilight Zone. No solid fills are showing in sections or elevations. They show in plans fine, and all other fills show correctly in sect/elev--just not solid ones and no matter what pen is chosen. Display options are set for all fills to display AS IN SETTINGS, fill background BY ELEMENT SETTINGS. I've been staring at these computer screens all day and I'm afraid I've lost my mind. What the heck am I overlooking?
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.6.1•AC 29 Silicon (latest build)
19 REPLIES 19
Rick Thompson
What is showing up in elevations.. any fills?
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
Dave Jochum
All other fills show correctly in sect/elev.
Dave Jochum
Dave Jochum
I thought maybe I was just fatigued last night when this occurred, but this morning I'm stumped. I can't believe this is an AC glitch, as it would have been found by others. Anyone have any ideas? Kinda frustrating
Dave Jochum
Rick Thompson
As far as I know, you never could unless the section/elevation is unlinked, then you can manipulate the fills as needed... or generate a 3D with parallel settings straight on. Is the screen shot what you are looking for? It was done with parallel settings and the internal engine.
Rick Thompson
Mac Sonoma AC 26
Dave Jochum
First of all, all fills that are defined within objects' settings in plan are showing fine in elevation. The problem is occurring when I'm CREATING a fill in an elevation window. Any fill I create here shows correctly--EXCEPT solid fills. That's it.
Dave Jochum
Dave wrote:
The problem is occurring when I'm CREATING a fill in an elevation window..
Hi Dave,
With the model view options that you indicated (background 'by element', fill 'as in settings' for all fill types), everything is fine for me...
Regards,
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Dave Jochum
UPDATE (weird): I just discovered one elevation in which solid fills will display properly, but all the other elevations and sections will not. As far as I can tell, the settings for the one "working" elevation is identical to all the others--i.e., object settings, model view options, layer combos.
Dave Jochum
Thomas Holm
I've no problem here either. (I normally use solid fills to cover items I don't want to display).
The only issue i've seen is that when I create them, they usually end up behind the auto-updated content of the S/E. So I have to bring them forward to see them. Once that's done, they stay in front.
Dave Jochum
Right--my experience has been the same. This is just goofy. I still cannot find a single difference between the settings of my one working elevation and the others.
Dave Jochum
