Roof Fascia Modeling: Is there a way to square off the bottoms of fascias in Archicad?
djstone
Is there a straightforward way to square off the bottoms of fascias in Archicad?
I've searched for a solution but haven't found a clear answer. As shown in my screenshot, I need the fascia bottoms to be squared off. It seems like this could be a simple feature within the custom edge settings but unfortunately there isn't an option. Currently, I’m using slabs on a hidden layer with solid element operations as a workaround, but this method can become quite messy. Since majority of my projects require this look, finding a more efficient solution would be incredibly helpful. If anyone has suggestions or best practices for achieving this more easily, I’d really appreciate the help.
10 REPLIES 10
Todd Thomas
Use a beam. You can change the ends using
Archicad 26
Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz 4.00 GHz
32GB RAM
Windows 10 Pro
If you work on Archicad 28, you can also place Openings into the Roofs to achieve the horizontal bottom cut of the Fascia. The Openings will be associated with the Roof.
Typically I'll use beams for my fascia, and assume the flat piece of fascia would "stop" the angled portion, meaning it would have about a 1" horizontal piece, or whatever thickness your fascia is. This is achieved using 3 beams per the screenshots below. To get the look you need per your screenshot, with the angled piece coming out to the face of the horizontal, the SEO trick mentioned by others is a workaround, as is modeling the angled portion with a custom profile beam and extruding it the thickness of the fascia.
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
If you place the Reference Line on the other side of those Beams, it will be easier to model them.
That is also a possibility but you need some amount of length of the smaller horizontal beam (non-highlighted portion shown 1/6" long below) to cut off angle, so the face of the angled fascia would never truly touch the face of the longer horizontal. I have the reference line where shown because when modeling trim, I usually put the reference line in relation to the "static" corner of the beam. In this case, if I ever wanted to quickly change the size of the fascia, I would want it to grow "down" and "out", away from the upper corner where my reference line is, if that makes sense. If placing baseboard with a beam, I would want it to grow "up" and "out".
Andrew Arkell
AC 18-27 USA 5030
If you are interested in helping me do some testing my roof covering does all this work in seconds.
How would I help testing this?
I like this option the best, I'm looking for the quickest way that would give me the same result as using beams. I wish Archicad would just have an option to customize your fascia within the roof settings.
Setup info provided by author
