2005-04-13
07:09 PM
2023-05-23
03:36 PM
Rubia Torres
2005-04-14 11:19 AM
Tom wrote:If I see correctly, the ACRoofConv.txt file is for converting Roof Accessory Objects coming from earlier versions to the version used by AC9. It happens when you open a Project in AC9 that was made with an earlier version.
I have posted this question before, but have had no comments. Maybe if I put it back to the front of the line it will get some more attention.
I would like to add a material to the list of materials available in roof surfacer. It is a tile material, but has an embossed "Y" shape on it. It is an antique style of metal roof that the Client would like to use.
I have found where the material index is located in the "add-ons" in the program files.
I can scan in a .jpg of the material, or actually make one using roof slab.
Any way to get the roof surfacer to put it on the roof? I don't know how to program like it is in the AcRoofConv.txt file in Extras under Program files.
If that is not doable, how can I put an 11" x 17" metal tile on an existing roof? Copy it in a matrix on an angle? Can I even do that?
I would appreciate all and any input.
