Roof not showing up in Elevations
Llian
Strange....why my roofs not showing up in elevations?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
Check the layer is on, use show all layers on the quick layer pallette.
Then check the renovation filter, show all.
...and also check that you did not limit the vertical height of the elevation below the roof level.
Llian
Thanks Roger and Karl.....
