2004-02-07 10:28 PM - last edited on 2023-05-23 03:44 PM by Rubia Torres
2004-02-08 03:06 PM
2004-02-08 07:09 PM
Tom wrote:Right click on the roof, select and activate tool. Keep left mouse button pressed on the edge you want horizontal, choose secod icon from tight, a dialog pops up, choose horizontal edge. Done.
A bit of clarification on my posting above. The slab is used as a sloped roof, 12/12 pitch. I'm talking about the horizontal cut at the bottom of the slab (rafter) where the soffit would be attached.
2004-02-08 10:10 PM
2004-02-08 10:24 PM
2004-02-08 10:35 PM
2004-02-09 06:07 AM
Tom wrote:Yep, one thing in plan, another in 3D. Forget Section or elevation - work in 3D window as much as you can, use the Virtual building!
Never mind, I found it. I guess it works only in plan, on the edge you want to change, right?
