Rotating the whole project. How?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2009-11-09 10:08 AM
Is there a way for me to rotate the whole project by 90 degrees? I am afraid of a fact, that i can only rotate the content of the specific floor, not the whole project(by this project, i mean the content of all the floors). Is this correct?
Or is there any way, i could just rotate the floor plans, at the printing layouts?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-09 01:51 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-09 05:29 PM
nedostizni wrote:You can rotate your whole project using the thick marquee or you can just rotate the plan in layout they way you would any other element or object. Be sure to choose a landscape format for the paper.
Ctrl+E is your friend.
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-09 05:49 PM
vistasp wrote:You may need to review the settings of your text, labels and zone tags so that they will print correctly.
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-10 03:01 AM
Erika wrote:True, that!
bT Square Peg
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-10 10:36 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-10 09:10 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-13 09:55 AM
That is a "heavy marquee". 4thhorns used this term here. Is that the marquee itselft? Or some other kind of marquee?
Also, when i put the marquee at the whole project of the floor story, for example, do i then have to choose Edit -> Select all, and then rotate around it`s projects center point?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-13 12:13 PM
So when doing this rotation, you need the thick Marquee, and have all your layers visible and unlocked.
Do not say Select All. Just use the Rotate command and all elements within the thick Marquee will be rotated. Yes, you should use the Project Origin as the center of rotation.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-16 10:01 AM
P.S.
The site is wonderful. Keep it that way, your brilliant.
