Rotating the whole project. How?
I have done some project (pretty big, about 4 hectars). I created it in, a shape of portrait (larger heigh, smaller width). Now it seems that i need to print it as a Landscape.
Is there a way for me to rotate the whole project by 90 degrees? I am afraid of a fact, that i can only rotate the content of the specific floor, not the whole project(by this project, i mean the content of all the floors). Is this correct?
Or is there any way, i could just rotate the floor plans, at the printing layouts?
Thanks.
13 REPLIES 13
vistasp
You can rotate your whole project using the thick marquee or you can just rotate the plan in layout they way you would any other element or object. Be sure to choose a landscape format for the paper.
Ctrl+E is your friend. 😉
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Erika Epstein
You may need to review the settings of your text, labels and zone tags so that they will print correctly.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
vistasp
True, that!
= v i s t a s p =
bT Square Peg
thanks for all the answers. You are all wonderful.
There is one other thing: if you have drawn 2D stuff in your Sections/Elevations then these will now not be at the correct location if you did not not rotate the whole Project around the Project Origin. So you have to check these if this case applies to you.
Thanks for the tip Laszlo.
That is a "heavy marquee". 4thhorns used this term here. Is that the marquee itselft? Or some other kind of marquee?
Also, when i put the marquee at the whole project of the floor story, for example, do i then have to choose Edit -> Select all, and then rotate around it`s projects center point?
When you draw a polygon or rectangle with the Marquee Tool its border can be thin or heavy. You can set on the Info Box which one. The thin one will select elements the Home Story of which is the current Story, the heavy (thick) border Marquee will select elements on all Stories.
So when doing this rotation, you need the thick Marquee, and have all your layers visible and unlocked.
Do not say Select All. Just use the Rotate command and all elements within the thick Marquee will be rotated. Yes, you should use the Project Origin as the center of rotation.
I don`t know how to thank you Laszlo. You are a god. Thanks once again.
P.S.
The site is wonderful. Keep it that way, your brilliant.
