rob2218
Rounded type stone wall base - Custom Profile?
see attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
6 Replies 6
I think you only have 2 options.
One is to model each stone individually - not impossible but not very practical.
Or create a complex profile as you have done, so it look reasonable in section.
Apply a surface material that has a stone hatch associated so it looks good in elevation.
That surface material could also be set up with bump map and displacement so it looks a bit lumpy in renderings as well if that is important.
rob2218
thanks Barry.
I thought that was the case.
it seems there is no way to create an irregular type stone profile like that.
I suppose that if I tried to just do that jagged shaped profile....it may end up looking strange cause you'll see horizontal lines running across the base too evenly huh?
hum...I may just do a slanted wall, add some texture map to it with some vectoral hatch pattern of similar round stones and call it a day.
Seems that's my only recourse.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Not if you use a spline to create the profile.
Curves won't show any horizontal lines (unless you see the top or bottom of the curve).
Erwin Edel
How about a wobbly line for the outline of the shape for section and just keep it as the 'box' shape for vectorial hatch and texture?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
rob2218
I could use a spline but any curved line when put into a profile causes havoc at corners if they aren't exactly meeting up just right. Strange Archicad resolution issues occur.
Besides, a curved line will take longer to process too and it's not that important to have.
Also, I could use that "sketchy" linetype as the profile linetype and just use a flat, canted sloping wedge of a profile. Maybe that's the way to go.
Trick the section into looking like a wiggly line, yet have the 3d model just have a flat canted wedge profile as the stone base and have texture on it.....
i>u
Edgewater, FL!
SOFTWARE VERSION:
Erwin Edel
That's excactly what I meant
www.leloup.nl
