Hello!
I am trying to trim off the upper part of a mesh from a stair, that is lying inside the mesh. With slabs, there is no problem. If I take a normal stair, no problem, but when I try it with a stair with two landing for example, Archicad doesn't trim the mesh correctly.
I had the same problem with walls. Could anyone help me ?
I have Archicad 8.1 on a Macintosh with MacOSX 10.3.5
Thank you in advance !!!!
