Chris Grantham
SEO Suddenly not working
I am trying to do the slab intersecting with a mesh to create pavement that follows the terrain trick, and for some reason nothing happens. This is something I have done many times, and SEOs work else where in the project so I am totally stumped. Anyone have any ideas? Thanks in advance!
-Chris
16" MacBook Pro M1 Max
Mac OS 26
ArchiCAD 27 Build 6010
1 Reply 1
vfrontiers
My experience doing exactly the same thing is that there is a point where it stops working.
Workaround is to INTERSECT all your roads then make copies of them to use as CUTTERS for the MESH. The problem [for me] occurs when I use the SLAB that has already been INTERSECTED w/ the mesh as the CUTTER for the same mesh.
Yes, it works sometimes, then will stop working. But I've always been able to SUBTRACT w/ UPWARD EXTRUSION using a 2nd slab that matches the first. These can reside on an OPERATERS layer to not show during 3d sessions.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
