2005-01-26
02:19 AM
2023-05-23
03:38 PM
Rubia Torres
2005-01-26 03:41 AM
Tom wrote:Tom, not entirely clear about you query. Why use SEO? I would have thought the roof tool could do what you describe.
I drew a roof bigger than it should be, then used the SEO to intersect it with another roof. ......
2005-01-26 03:48 AM
2005-01-28 07:10 AM
Tom wrote:Intersecting roof planes is still best done using the old CTRL click method. Does it properly.
I drew a roof bigger than it should be, then used the SEO to intersect it with another roof. I see that everything intersected fine, but the original outline of the roof (which I thinkis a fill outline) does not move back to where it was intersected with the other roof.
2005-01-28 02:17 PM
2005-01-28 02:26 PM
Tom wrote:As I've said many times, "The Help Menu is your friend!"
What is the old CTRL click method.
Actually, I used the roof tool to draw a ceiling planes on a sloped ceilings. I did not any other way to make them intersect, other than drawing the ceiling lines in 2d as you would show in a reflected ceiling plan, then moving the nodes of the roof to the appropriates spots.
So any other way to accomplish that task would be appreciated.
2005-01-28 02:47 PM
2005-01-29 05:39 PM
Tom wrote:Roofs are polygons.Intersecting roof planes is still best done using the old CTRL click method. Does it properlySo any other way to accomplish that task would be appreciated.
