‎2006-09-21
08:58 PM
‎2023-05-25
04:36 PM
Rubia Torres
‎2006-09-26 11:34 PM
Rory wrote:Rory, my friend, if you knew what has gone on behind the scenes you would not call me, or any of the frequent contributors to this list, complacent. We have all participated in multiple beta tests and much more. But there is only so much we can do, and that's not really very much. Your complaints are valid and you're right, we deserve more for our loyalty and money. The reason we all put up with it is because ArchiCAD is the best solution available. When that is no longer the case I will switch.
Being complacent towards these shortcomings perhaps is the very reason why they remain...
‎2006-09-27 05:56 AM
James wrote:Magic wand does wonders sometimes ...Matthew wrote:Or conventional beams?
You can curve profiled beams????
‎2006-09-27 05:08 PM
You can curve profiled beams????yes you can, just use the magic wand on the curve you want, and poof, there it is. Now try that same profile with the wall tool and magic wand the same curve, and see what happens
‎2006-09-28 08:48 AM
Djordje wrote:I prefer facets on gemstones, but you sometimes you take what you can get.James wrote:Magic wand does wonders sometimes ...Matthew wrote:Or conventional beams?
You can curve profiled beams????😉
‎2006-09-28 09:32 AM
Matthew wrote:beams still cannot be curved - the magic wand is just automating the task of faceting a lot of straight beams all at once . . . a touch of lateral thinking rather than an undocumented upgrade i think!
Or is this some undocumented upgrade that we haven't heard of?
