SEO's with Archiforma objects
David Collins
I've been casting big bronze bells in ArchiForma and I've discovered two things that surprised me:
- Archiforma objects can be used to do SEO operations on each other.
- If you make a library object out of the target element using Fabrizio's object tool, the new object will retain the SEO operation, without the operator element!
BONG!
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
1 REPLY 1
Fabrizio Diodati
BONG... BOONG... BOOOOOONG!!!
IT SHOULD BE VERY INTERESTING (sorry if I’m screaming but this bell is so noisy!) TO GET SOME GOOD IMAGES OF YOUR BELL IN ORDER TO PUT THEM IN THE ARCHIFORMA GALLERY EXAMPLES.
Friendly
Fabrizio
Fabrizio Diodati
