2015-11-27 03:22 AM - last edited on 2023-05-24 12:42 PM by Rubia Torres
2015-11-27 07:51 AM
2015-11-27 08:15 AM
TiggerF wrote:Thanks a lot mate.
you could turn the slab layer off for elevations, and then adjust the layer priorities.
2015-11-27 08:33 AM
2015-11-27 08:49 AM
2015-11-27 03:17 PM
2015-11-30 12:08 AM
2015-11-30 01:43 PM
2015-12-01 12:52 AM
David wrote:Thanks a lot David.
tranthainguyen:
The Wall goes through the Slab. You have a couple options:
1. Copy the Wall so there are two Walls, one on each Story. The top of the lower Wall should match the bottom of the Slab, and the bottom of the upper Wall should match the top of the Slab.
2. SEO the Wall and the Slab.
3. Pull the edge of the Slab back so it meets the inside face of the Wall.
