Save & place on a layout question
Created a separate layer for stairs in plan so that they would not
show on the reflected ceiling plan and now they don't show on some layouts that were created earlier. In this case, is there a way to get the placed layout to show the new layer settings with out having to replace the drawing?
Just update the relevant Layer Combinations with the stair layer turned on. The easiest way to do this is in Layer Settings select the Stair layer, then click on the Show Layer (eye) button for each of the LC's (on the left hand side) you want to update.
