Saving 12 Files as 10
Is it possible to save ArchiCAD 12, 13 & 14 .pln's as ArchiCAD 10 Files?
TMA_80
AFAIK, You can't , you need ArchiCad11 which will allow you to save as archicad10 file format...
AC12_27 |Win11_64bit|
See:
http://www.archicadwiki.com/ArchiCAD%20versions
Near the bottom is a table of what versions each version of AC can read and write. As TMA says, 11 can save back to 10 (12 to 11, 13 to 12 etc.)
When back-saving, not only would you lose any info related to new features, if utilized in the project, but library parts cannot be saved backwards or opened in older versions.
Sorry,
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
