Segmental Arched Transom or Window
dhaval7shah
Hello, can Anybody please guide me , where can I get the 'Segmental Arched Transom or Window' from ? (not a full radius top, but Segmental Arch)
Dhaval Shah
Upto AC 22
iMacs and MacBookPros: Mac OS X (10.6 to 10.12, Intel core 2 Quad to i5, i7, 8 GB to 16GB)
Win 10, AMD Opteron 6-Core x 2, 16GB, FirePro W4100 2GB
& ThinkPad E550
& i7, 8GB
6 REPLIES 6
vistasp
AC version?
You should add it to your signature, Dhaval. Along with your system specs.
Cheers.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
dhaval7shah
Its version 12, thanks.
Dhaval Shah
Upto AC 22
& ThinkPad E550
& i7, 8GB
vistasp
Dhaval, whenever you can't locate a library part, use the "Find Library Parts" or "Subtype View".
I'm repeating myself but you really should add at least your AC version and OS to your signature.
Avjo.
= v i s t a s p =
bT Square Peg
dhaval7shah
I want to put a seperate transom or window with segmented radius top.
As these shapes are usual in architecture, and i wonder that I could not find this element in a leading BIM software ArchiCAD.
Kindly guide me.
Dhaval Shah
Upto AC 22
& ThinkPad E550
& i7, 8GB
vistasp
Dhavalbhai,
I've given you the example of a segmented door which you can insert using the door tool. Use the window tool to find a similar segmented window - with a transom or otherwise.
= v i s t a s p =
bT Square Peg
You can use arched windows and window openings from ArchiCAD 12 Standard Library. Just set the "Curve resolution" parameter according to the number of segments which you need.
For example, for "W Arched Cas 12" windows you should open "Parameters" block, then open "3d Representation" and see "Curve resolution" parameter.
As for openings, you can see the "Curve resolution" just at the top part of parameters list.
