Select in 3d, SHOW in 2d
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2014-03-07
11:41 AM
‎2023-05-23
04:26 PM
Rubia Torres
‎2014-03-07
11:41 AM
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-03-07 06:18 PM
‎2014-03-07
06:18 PM
For a long time I struggled to select objects, but I just can't GRAB THEM. Either they just won't get selected or I get another object that I don't want. So I understand why you turned to 3D, it's easier to make a selection that way. But there's a problem in 3D... it's hard to move objects accurately on the x-y plane.
Before you go into 3D, try to play with the 2D window. There are different ways to select an object. There's the quick selection, which is convenient when selecting large area objects. But for a group small objects, you might want to draw a selection area ( it can be any shape, usually rectangle ).
Now, as for objects that's hard to grab, move your cursor around the objects, especially the corners, because that's where the 2D hotspots are located. Think of 2D hotspots as spots on the objects which you can grab with you hands.
Finally, if all fails, like you did, switch to 3D, select the object, and move it to the ArchiCAD Layer ( or any layer that contains no objects, the ArchiCAD layer is usually empty for the 2D window), then, using the Quick Layers, hide all layers, except for the one the object is on. This way the object you want to select will be the only object visible on the 2D window, select it, and make other layers visible again.
Unfortunately this seems to be the only way to select an object in 3D and then select it in 2D.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-03-07 08:20 PM
‎2014-03-07
08:20 PM
The following seems to work for me:
1. Bring up the Window\Palettes\Selections Palette.
2. Save the selected elements as a Selection.
3. Notice what their Home Story setting is (e.g. 1. Story)
4. Use the Project Map to navigate to that story in 2D.
5. Double-click the saved Selection to select them on the Floor Plan.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-03-07 09:34 PM
‎2014-03-07
09:34 PM
alexwang32 wrote:In plan, if you have multiple elements sharing a common point, you can
... I just can't GRAB THEM. Either they just won't get selected or I get another object that I don't want. …..
toggle through the objects but tapping the "TAB" key. Select more than one
object by "shift" clicking (shift click to de-select, too). If you have tracker
turned on, it will tell you there are Multiple elements.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-04-01 01:38 PM
‎2015-04-01
01:38 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-08-09 03:25 PM
‎2021-08-09
03:25 PM
This feature has been implemented in Archicad 25.
