There probably is a wish for this already as it has been wanted for a long time.
The problem is probably not so bad going from 2D to 3D - in fact you can simply choose to 'Show selection in 3D' now.
The big problem comes when you select in 3D or elevation and want to go back to plan.
In 3D elements can be on many storeys but the plan can only show one at a time.
So what happens to all those other elements that are selected?
Can they simply be filtered out because they are not on the correct storey?
And if you now change storeys will the other elements that were selected still be selected?
And if you were to unselect something in the plan are the elements in the other storeys still selected so if you press DELETE or move something still selected in the current plan will they all delete or move as well?
Probably not insurmountable problems but I can imaging it will need a lot of re-writing of code in the program.
