2019-08-01
05:54 PM
- last edited on
2023-05-23
06:00 PM
by
Rubia Torres
Solved! Go to Solution.
2019-08-02 02:06 AM
Alessandro wrote:.
Hello! Can someone help me?
I'm not able to change the material of every elements of a railing in a single action.
Is it possible?
Thank you![]()
2019-08-02 02:06 AM
Alessandro wrote:.
Is it possible?
Thank you![]()
2019-08-02 03:22 AM
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2019-08-02 09:21 AM
2019-08-02 09:37 AM
2019-08-02 11:28 AM
Lingwisyer wrote:.
It doesn't take much to add a toggle for this function, so hopefully it will be there in a later update and / or AC23.
Ling.
2019-08-02 11:28 AM
Erwin wrote:.
Some objects have parameters inaccesible from the object UI. By making a schedule and listing those parameters you can easily change them for multiple objects at once.
Perhaps as a similar workaround you can schedule the railing surfaces sorted by railing part and by using 'merge uniform items' can quickly change the surface for multiple elements at once.
2019-08-02 11:53 AM
2019-08-02 01:43 PM
2019-08-05 04:33 PM
