Archicad 22 - Single material railing
Hello! Can someone help me?
I'm not able to change the material of every elements of a railing in a single action.
Is it possible?
Thank you
1 Solution
Is it possible?
Thank you
Both the rail and stair tool, as far as I know, don't have the ability to globally assign a material or pen for 2D or 3D. It has become so time consuming for me that I don't use either of these tools unless I have no other choice. I'll just create a custom object. It's a shame that they took out a perfectly good feature that every other ArchiCAD tool has for no good reason.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
Go to post
9 Replies 9
Is it possible?
Thank you
Lingwisyer
Guru
It doesn't take much to add a toggle for this function, so hopefully it will be there in a later update and / or AC23.
Ling.
I agree with you! Thank you!
Erwin Edel
Some objects have parameters inaccesible from the object UI. By making a schedule and listing those parameters you can easily change them for multiple objects at once.
Perhaps as a similar workaround you can schedule the railing surfaces sorted by railing part and by using 'merge uniform items' can quickly change the surface for multiple elements at once.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Ling.
The fact that these two tools have been around for two or three versions already, I'm not holding my breath. This is really the single-most reason I don't use them unless I have to.
Sometimes it's the little things that affect you most.
Interesting solution for a workaround. I'll try this. Thanks!!!
Intersting. Thank you!
Erwin Edel
Let us know if it works, I know it works easily with objects since the surfaces are a parameter and you can ussually change object parameters from schedule if you list them.
It will work a little different for railing tool, but maybe it works.
I think I used edit railing and then Find & Select to get all the similar parts and change them at once per railing. Not a real mass change, but quicker than each part one by one.
www.leloup.nl
I tried but without good results... No problem. Thanks at all.
