‎2019-08-01
05:54 PM
‎2023-05-23
06:00 PM
Rubia Torres
Solved! Go to Solution.
‎2019-08-02 02:06 AM
Alessandro wrote:.
Hello! Can someone help me?
I'm not able to change the material of every elements of a railing in a single action.
Is it possible?
Thank you![]()
Alessandro wrote:.
Is it possible?
Thank you![]()
‎2019-08-02 03:22 AM
‎2019-08-02 09:21 AM
‎2019-08-02 09:37 AM
‎2019-08-02 11:28 AM
Lingwisyer wrote:.
It doesn't take much to add a toggle for this function, so hopefully it will be there in a later update and / or AC23.
Ling.
Erwin wrote:.
Some objects have parameters inaccesible from the object UI. By making a schedule and listing those parameters you can easily change them for multiple objects at once.
Perhaps as a similar workaround you can schedule the railing surfaces sorted by railing part and by using 'merge uniform items' can quickly change the surface for multiple elements at once.
‎2019-08-02 11:53 AM
‎2019-08-02 01:43 PM
‎2019-08-05 04:33 PM
