Archicad 22 - Single material railing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-08-01
05:54 PM
‎2023-05-23
06:00 PM
Rubia Torres
I'm not able to change the material of every elements of a railing in a single action.
Is it possible?
Thank you
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-08-02 02:06 AM
Alessandro wrote:.
Hello! Can someone help me?
Is it possible?
Thank you![]()
Both the rail and stair tool, as far as I know, don't have the ability to globally assign a material or pen for 2D or 3D. It has become so time consuming for me that I don't use either of these tools unless I have no other choice. I'll just create a custom object. It's a shame that they took out a perfectly good feature that every other ArchiCAD tool has for no good reason.
ArchiCAD 27 (user since 3.4, 1991)
16" MacBook Pro; M1 Max (2021), 32GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Alessandro wrote:.
Is it possible?
Thank you![]()
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-08-02 03:22 AM
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-08-02 09:21 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-08-02 09:37 AM
Perhaps as a similar workaround you can schedule the railing surfaces sorted by railing part and by using 'merge uniform items' can quickly change the surface for multiple elements at once.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-08-02 11:28 AM
Lingwisyer wrote:.
It doesn't take much to add a toggle for this function, so hopefully it will be there in a later update and / or AC23.
Ling.
The fact that these two tools have been around for two or three versions already, I'm not holding my breath. This is really the single-most reason I don't use them unless I have to.
Sometimes it's the little things that affect you most.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Erwin wrote:.
Some objects have parameters inaccesible from the object UI. By making a schedule and listing those parameters you can easily change them for multiple objects at once.
Interesting solution for a workaround. I'll try this. Thanks!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-08-02 11:53 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-08-02 01:43 PM
It will work a little different for railing tool, but maybe it works.
I think I used edit railing and then Find & Select to get all the similar parts and change them at once per railing. Not a real mass change, but quicker than each part one by one.
www.leloup.nl
Windows 10 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-08-05 04:33 PM
