SOLVED!
Selecting Doors & Windows
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-12-23
02:32 PM
- last edited on
2023-05-09
03:47 PM
by
Rubia Torres
2020-12-23
02:32 PM
I seem to have trouble selecting doors and windows after having placed them.
I hit the Tab button multiple times but this seems to toggle between the wall and slab a few times before getting to the door.
It seems I miss the "selecting handle" for the door or window,
Is there some trick to this, or a specific area on the door that the mouse pointer need to be at in order to easily select it?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
Windows 10 Pro
Solved! Go to Solution.
1 ACCEPTED SOLUTION
Solution
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-12-24 01:39 AM
2020-12-24
01:39 AM
If you have 'Quick Selection' active (the magnet - the space bar key is the temporary on/off toggle), you should find that you can hover anywhere over the opening in the wall and you should be able to select the door window.
Otherwise you have to select it by the corners of the opening or there should be a centre spot.
Or as mentioned there is usually one at the end of the door leaf.
Also as mentioned, having the door or window tool active and holding SHIFT while selecting, will give priority to selecting the door or window (or element belonging to the tool you have active).
2 REPLIES 2
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-12-23 03:39 PM
2020-12-23
03:39 PM
The door leaf end should have a selectable hotspot. Or the door marker.
General rule - if you have the correct tool selected, in this case the door tool, then a shift+click will always select the correct element.
| Archicad 4.5 - 29
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
Solution
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-12-24 01:39 AM
2020-12-24
01:39 AM
