Selection causing drag to start
Narska
When selecting an object or element, there is a short lag after which the element goes into drag mode.
How to address or fix this?
Operating system used: Mac Intel-based Sequia 15.1
Tomasz Mlynarski
New York based Architect
2 ACCEPTED SOLUTIONS
Is this the same problem?
https://community.graphisoft.com/t5/Modeling/Apple-M1-Units-I-select-items-and-they-always-want-to-m...
Yes! Magnet App was causing it! Thank you.
Tomasz Mlynarski
Tomasz Mlynarski
Setup info provided by author
