7 hours ago
Hello, I wonder if it is possible to draw a shaft throug more floor plans in Archicad at once and if not how do you do it so it is not so time consuming?
Thank you for all answers.
Solved! Go to Solution.
7 hours ago
If I understood correctly there are 2 quick options:
The other option is to use the opening tool and link all the slabs
another Moderator
7 hours ago
another Moderator
