Bara3
Shaft/slab section throug more floor plans
Hello, I wonder if it is possible to draw a shaft throug more floor plans in Archicad at once and if not how do you do it so it is not so time consuming?
Thank you for all answers.
1 Solution
Eduardo Rolon
If I understood correctly there are 2 quick options:
  • The faster is in the 3d Window select all slabs that will have the shaft and draw the "hole" which will be reflected on all.
  • The other option is to use the opening tool and link all the slabs
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
Eduardo Rolon
AC29 US/INT -> AC08
And another method.
Draw an element to represent the shaft (column is easy) and then convert it into a morph.
Then select it and right mouse click > Connect > Create Openings from Selection.
Choose the shape and offset if you want one and turn off 'Keep Original Elements', then create the opening.
https://help.graphisoft.com/AC/27/INT/index.htm?rhcsh=1&rhnewwnd=0#t=_AC27_Help%2F040_ElementsVB%2F0...
