Show On All Relevant Stories
JKL
I am attempting to get my plumbing to show on the foundation. My employer wants the "Site" story above the "Foundation" story in the story settings within our template. So when I select all my plumbing objects I wish to show, I cannot select the display option for "home and one below", as below is the site.  When I select all relevant stories, some of the items (namely, sinks) are showing but not the rest of the plumbing.
Objects are all on the same layer
Cut plane settings are correct to view (I can see the walls on the story above appropriately)
The sinks actually sit higher than the other items (toilets etc)
All obj settings are the same for what I can see vs what isn't showing
Aside from blowing up the model and switching my stories around or putting new objects on the foundation plan-neither of which I want to do-what can I do here to get all the objects to show correctly on the foundation?
I've a series of images below with a sink and toilet as example.
Thank you!
Traced elements here should be showing as sink is
But only sinks are actually viewable
sink settings
toilet settings
 Foundation cut plane settings
Story settings
Designer
Mac
Archicad 26
6 REPLIES 6
Marc H
Coincidentally, I tried Site above Foundation on a recent project (the idea being a visible match between exterior and interior elements), but it created more issues than it solved.
Meanwhile, the ‘relevant stories’ is an unfortunate limitation I hope GS converts to a custom selection in which we can select applicable stories for our increasingly complex project elements. Maybe this will be part of the ‘split level’ roadmap improvements.
One workaround if you are forced to keep it this way may be to overlay two drawings on your layout; one for each story, with a gray GOR applied on the upper story view.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Why you can't find ( Home story and one below) in your display options?
This is strange,
for me in 26 INT I've this option valid.
AC 28 INT 3110/WIN 11
Unfortunately, the options with home story and (+options) and custom are only options for slabs, beams and columns (I may be missing something else) in the US version. All other items are only home or all relevant. I would think everything should have the (+) options!
Designer
Mac
Archicad 26
This may work!
I think I'm going to have to reset the template to put the site under foundation to avoid future issues. Let me know if you come up with any good solutions keeping the story settings a visual match to the project!
Designer
Mac
Archicad 26
JKL:
These are the options I see for WC 26. Are you using a different library part?
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
This is not to everyone's taste, but I do not set up storeys for foundation and site.
I have a storey for the ground floor ant that is it.
I use layers for the foundation walls and the site elements (dxf site plan, 3D site mesh, etc.).
Then you set up some layer combinations to turn on/off the layers you want to see, and save a view for each layer combination.
To me storeys are purely for each floor level, i.e. ground floor, basement, first floor, second floor, etc.
I don't even uses storeys for ceiling and roof levels.
But that is just the way I like to work.
