Showing dashed in section what's beyond the cut plan
I have a slab with a hole cut thru it and I want a section view to show me the hole thru the slab as a dashed line. Is this possible? And if not, why not ? It isn't a library part, just a slab with a hole in it.
Thanks,
Michele
5 Replies 5
David Larrew
No, not in this version of AC.
You would have to draw the hidden/dashed line representing the hole in the Section/Elevation window. Of course if the hole moved, you would have to edit the placed lines manually.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Hi Michele,
Do you mean something like the image below? (Click to enlarge it.)
The dashed lines are via the Special Menu...something I just learned here recently, but I can't find the post in the archives. Turn on 'Show special lines' and select your dashed linetype under 'Special hidden line...' I'll post more if that isn't clear.
David is right - we cannot change the linetype of distant elements in a section (only the pen) ... but your question sounded more like you were asking about hidden lines than distant ones.
HTH ... but I probably misunderstood what you're asking,
Thanks Karl! That's exactly what I needed! I heard about the special menu but never got around to actually looking at it.
Thanks for broadening my knowledge!!
MIchele
David Larrew
Doh! That's right I forgot about the "Special Menu". I've had mixed results working in ArchiCAD with the SM active - sometimes detrimental. I try to stay away from the SM on billable projects on deadlines. But, to each his/her own!
AC 5.1-25 USA
Djordje
Karl wrote:
this belongs in the Tips section:
http://www.escribe.com/software/archicadtalk/m34966.html
http://www.escribe.com/software/archicadtalk/m34968.html
It definitely does!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
