Showing lines in 3D view
hi all, is there a way to make a line drawn with the like tool show in
the 3D window? I am trying to build a wireframe model, but the lines are not showing in 3D space
any ideas or suggestions
thanks 😃
11 Replies 11
Dwight
BTW: Since you are using this model as a schematic for programming, why not consider using translucent zones instead?
Dwight Atkinson
Or to follow up on Steve's response...
A simple model of slabs, roofs and meshes can be viewed in either wire frame or hidden line mode. I'm not sure about saving the model as 3D lines that can be used in another program if that is your intent. If all you need is a wireframe to print and sketch over this would work fine.
