Slab Accessory - Footing
Rick, wrote:
I'm an archicad software user, i have a question for you regarding the Slab Accessory - Under Footing Settings..
I want to find the way to stretch the footing size, i did explode it, but it didn't work please tell me if there is another way to resize the footing...i was ungrouping the Object to stretch out the Object, but i couldnt do it...Please let me know how to re-adjust it.
First ... since this is my second PM in two days from new forum users with theretofore zero posts: I don't get paid to do this. So, please post your question on a forum addressed to the world at large. If you post directly as a PM to me, I'll assume you want to hire me as a consultant (I am a hired gun - I do not work for Graphisoft) and will need to bill you up front. 😉
Rick,
The slab accessories, like all accessories, are applied by selecting the element first (the slab), then the accessory. The accessory will then morph itself to match the slab (or wall, for wall acc'y, etc.).
The Footing object is not hot stretchable. All parameters are set within the object settings dialog (see screenshot). You can adjust stem wall thickness and height, footing thickness and height, plate dimensions, etc.
The names of the parameters are a unfortunate. The screenshot shows the SE library version. What they call 'footing height' is what we call 'footing depth'. What they call 'thickness' is what we call 'footing width'. (Ditto stem wall dimensions.) Slowly, GS is customizing the US library to better user US terminology ... but looks like none of us reported this one.
If you explode any AC element - object or otherwise - it turns into 2D lines and fills. It will no longer be 3D. This has uses at times, but is not what you want here.
You cannot ungroup an AC object into subcomponents either. An object is an element. You can only alter its appearance via parameters (or solid element operations when necessity calls).
Hope that helps ... post any more questions to this thread. 😉
Regards,
18 REPLIES 18
Petros Ioannou
Well this is what you get for talking too much!
After all don't forget you are the winner!
http://archicad-talk.graphisoft.com/viewtopic.php?t=6612&start=0&postdays=0&postorder=asc&highlight=
cheers
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Aussie John
Obviously someone panicking as I got the same PM
Cheers John
[/size]
__archiben
yep - me too - although karl beat me to the response
cheers
~/archiben
b e n f r o s t
Djordje
You too?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
TomWaltz
I got one too.... I guess we're just popular!
Tom Waltz
TomWaltz
Karl,
you are even catching up with Matthew & Dwight on number of posts!
Tom Waltz
TomWaltz wrote:
Karl,
[Gratuitous extra post!]
Now that I know that Rick contacted all of you guys, I don't feel 'special' anymore. (But, to Rick: I did not use your user-id, so if you post more questions in the future, nobody will know who you are. You'll find that if you post to a forum, that SOMEBODY will answer almost as quickly as you could have sent that many PM messages. Somebody in some time zone is awake and on a break. 😉 Welcome to the forum.)
Karl wrote:
(But, to Rick: I did not use your user-id, so if you post more questions in the future, nobody will know who you are .... Karl
That is only the nobodies that were not "special" enough to be selected to the PM group.
Nobody, Jay (No were near Top Postings, no matter what is counted)
[EDIT: Actually I see that I am Firmly in the Top 10 for Total Attachments. This is because typing is a not a strong-suit for me. And I "are" an engineer. Pictures are worht 10,000 words.]
See how I "recycled" this post.... Now I should have just made a reply post in order to add to my total. Well, now all I am doing i s a d d i n g t o m y w o r d c o u n t .
The other reason for a public forum, besides improving your chances of getting an answer, is that by asking you might help someone else with the same problem. Not that you shouldn't hire Karl.
Apparently just below some specialness threshold,
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
